Renesas RX62N & RX63N using the Renesas Compiler and IDE
[Embedded Ethernet Examples]
This page presents the Renesas RX62N
and Renesas RX63N FreeRTOS port and demo application that uses the Renesas RX compiler,
and HEW IDE. RX62N projects are provided that target both the
and Renesas RX62N Demonstration Kit (RDK) boards. An RX63N project
is provided that targets the RX63N RDK.
Note that compiler version 1.0.1.0 or higher is required.
Demo applications are also available for the IAR and GCC compilers.
Included in the demo is an example web server that is implemented using a modified version of Adam Dunkels open source uIP
embedded TCP/IP stack. Code-named FreeTCPIP, the modifications allow for
higher throughput than that achievable with the original code. The CGI
scripting facility is used to display both RTOS and TCP/IP run time information.
uIP is licensed separately from FreeRTOS. Users must familiarise themselves with the
uIP licence, which is included at the top of each uIP source file.
IMPORTANT! Notes on using the Renesas RX62N port and web server demo
- Source Code Organisation
- The Demo Application
The HEW workspaces for the RX62N RSK and RDK development boards are both called RTOSDemo.hws and are located in the
FreeRTOS/Demo/RX600_RX62N-RSK_Renesas and FreeRTOS/Demo/RX600_RX62N-RDK_Renesas directories
respectively.
The HEW workspace for the RX63N RDK development board is also called RTOSDemo.hws and is located in the
FreeRTOS/Demo/RX600_RX63N-RDK_Renesas directory.
The FreeRTOS zip file download contains the implementation of all the FreeRTOS ports and every demo application project.
It therefore contains many more files than used by this demo. See the
RX62N & RX63N Demo Application
Three build configurations are provided:
Build configuration
Description
Blinky
This is a very simple example that just creates two tasks. The
tasks communicate via a queue, with an LED being toggled upon each
successful queue receive. The Blinky build configuration includes
main-blinky.c, where as the other build configurations use
main-full.c.
Debug
A very comprehensive demo that creates nearly 50 demo tasks before starting the RTOS scheduler, then continuously dynamically creates and
deletes another two tasks as the application executes. The tasks consist
mainly of the standard demo tasks - which don't perform any
particular functionality other than testing the port (including interrupt nesting) and demonstrating how the FreeRTOS API can be used.
Information on additional tasks that are created is provided immediately below this table.
Debug_with_optimisation
Adds a high frequency timer test to the tasks and tests executed by the Debug build configuration, plus tests that the tasks and
tests execute correctly with the optimiser switched on.
- Check task
This only executes every five seconds but has the highest priority to ensure it gets processing time.
Its main function is to check that all the standard demo tasks are still operational. The check function
maintains a status string that can be viewed at the very bottom of the "Task Stats" page served by the integrated web server.
It also toggles LED5 (RSK) or LED9 (RDK). If the check LED is toggling once every five seconds then all the
demo tasks are executing without any errors having been reported. If the toggle frequency increases to once every
200ms then an error has been detected in at least one task.
Some of the tasks check to ensure their own execution timing remains within fixed limits, and with nearly 50 tasks executing these limits can sometimes
be breached causing an error to be reported where none really exists. The timing constraints can be put under even more stress when the 20KHz interrupt
is running too. Therefore an error being reported is not necessarily indicative of an error in the FreeRTOS port, but just a symptom of a task not getting
the CPU time it requires to remain within its tight (self imposed) timing constraints.
- uIP task
This is the task that executes the TCP/IP stack. All network processing is performed in this task, making the TCP/IP
Flash footprint extremely small when compared to other embedded TCP/IP stacks.
- Reg test tasks
These two tasks fill the microcontroller registers with known
values before checking that each register still contains its expected value. Each of the two tasks
use different known values. The tasks run with very low priority so will get preempted very
often. If a register ever contains an unexpected value then an error has occurred - probably in the context
switching or interrupt mechanism. The reg test tasks write directly into specific registers, necessitates that
they are written in assembly code.
- High frequency timer test
This test configures a timer to generate an interrupt at 20KHz. The interrupt priority is above
configMAX_SYSCALL_INTERRUPT_PRIORITY so should not be
effected by anything else the RTOS kernel is doing. The jitter experienced in the interrupt timing is measured and
displayed at the bottom of the "Run Time Stats" page served by the integrated web server.
Web server configuration
The IP address used by the RX62N is set by the constants configIP_ADDR0 to
configIP_ADDR3. These can be located at the bottom of the
FreeRTOSConfig.h header file that is located in the chosen project directory.
Constants that define the MAC address and the NET mask can be found in the same file.
The IP addresses used by the web browser and the RX62N development board must be compatible.
This can be ensured by making the first three octets of both IP addresses the same.
For example, if the web browser computer uses IP address
192.168.0.1, then the RX62N development board can be given any address in the
range 192.168.0.2 to 192.168.0.254, other
than any addresses that already exist on the same network.
The MAC address assigned to the RX62N must be unique on the network to which
it is being attached.
- Connect the chosen development board to a computer running a web browser either directly using a point to point (crossover)
cable, or using a standard Ethernet cable through a hub or switch (only point to point has been tested, but both should work).
- Before opening the project - if using an RSK development board connect the RSK to the host computer using an E1 JTAG interface
(provided as part of the RSK) then apply power. If using an RDK development board just connect the micro USB socket on the RDK that is marked J-Link to the host
computer - no separate power is required. The HEW will attempt to connect to the chosen development board as the project is opened.
- Open the selected RTOSDemo.hws workspace from within the HEW IDE - following the instructions
to connect to the target interface as the project opens.
- Select "Build" from the HEW "Build" menu - the demo application should build without errors although some
[inexplicable] dependency errors and some [incorrect] warnings are produced - these will not effect the build.
- When the build completes a dialogue box will appear asking if you want the produced binary to be downloaded to the
microcontroller flash memory - select "yes" to program the flash and start a debug session.
An executing demo application should behave as follows (LED numbers are correct for the RSK, numbers in brackets are correct for the RDK):
- LEDs LED0, LED1 and LED2 (4, 5 and 6 on the RDK) are controlled by the standard 'flash' tasks. Each will toggle at a fixed but different frequency.
- LED5 (9 on the RDK) is controlled by the 'check' task and will toggle every 5 seconds if no errors have been detected.
- LED3 and LED4 (11, 12, 13 and 14 on the RDK) can be turned on and off interactively using the IO page served by the integrated web server.
- The integrated web server will serve the web pages described below to a standard web browser. To connect to the target:
- Open a web browser on the connected computer.
- Type "HTTP://" followed by the target IP address into the browsers address bar.
Served web Pages
![](/fr-content-src/uploads/2018/07/SH7216-task-stats-page.jpg)
![](/fr-content-src/uploads/2018/07/SuperH-task-run-time-page.jpg)
![](/fr-content-src/uploads/2018/07/SH2A-IO-page.jpg)
The served IO page
The IO page provides a simple interface to permit various LEDs to be turned on and off from a web browser. The LED number will be correct for the RSK only.
Changes are sent to the target board whenever the "Update IO" button is clicked.
Other served pages include TCP/IP statistics and a large JPG image. All the web pages are included in the downloaded
binary image - which can make the binary image appear to be quite large (the jpg file by itself is in excess of 36K).
Configuration items specific to this demo are contained in FreeRTOS/Demo/RX600_RX62N-RSK_Renesas/RTOSDemo/FreeRTOSConfig.h or
FreeRTOS/Demo/RX600_RX62N-RDK_Renesas/RTOSDemo/FreeRTOSConfig.h for the RSK and RDK hardware respectively. The
constants defined in these file can be edited to suit your application. In particular -
- configTICK_RATE_HZ
This sets the frequency of the RTOS tick. The supplied value of 1000Hz is useful for
testing the RTOS kernel functionality but is faster than most applications need. Lowering this frequency will improve efficiency.
- configKERNEL_INTERRUPT_PRIORITY
This defines the interrupt priority used by the RTOS kernel for the timer and software interrupts. This should always be set to
the lowest interrupt priority, which for the RX62N is 1. See
- configMAX_SYSCALL_INTERRUPT_PRIORITY
This defines the maximum interrupt priority from which FreeRTOS API functions can be called. Interrupts at or below this
priority can call FreeRTOS API functions provided that the API function ends in 'FromISR'. Interrupts above this
priority cannot call any FreeRTOS API functions but will not be effected by anything the RTOS kernel is doing. This makes
them suitable for functionality that requires very high temporal accuracy. The high frequency timer test included in this
demo application uses a priority that is above configMAX_SYSCALL_INTERRUPT_PRIORITY. See
Interrupts can be written using the standard Renesas compiler syntax. For example, the demo application defines the
high frequency timer using:
re-enables interrupts on function entry. This will allow interrupts to nest
interrupt in the demo). */
See the examples provided by Renesas and the compiler
documentation for full details.
Often an ISR wants to cause a context switch so the task that is returned to when
the ISR completes is different to the task that the ISR interrupted. This would
be the case if the ISR caused a task to unblock, and the unblocked task had a
priority above that of the task that was already in the Running state. This
can be achieved by calling portYIELD_FROM_ISR(), which takes a single parameter.
The parameter should be 0 if a context switch is not required, or non-zero if
a context switch is required. This is demonstrated in the code below - which is
a handler for a cascaded 8 bit timer 0 and timer 1 compare match interrupt.
re-enables interrupts on function entry. This will allow interrupts to nest. */
#pragma interrupt ( vT0_1InterruptHandler( vect = VECT_TMR0_CMIA0, enable ) )
void vT0_1InterruptHandler( void )
FreeRTOS also requires exclusive use of a timer that is capable of generating the tick interrupt - but
it is up to the application writer to define which timer that is.
The application must define a function called vApplicationSetupTimerInterrupt() to
configure the tick interrupt, then define configTICK_VECTOR to inform the RTOS kernel of the interrupt vector
number of the chosen timer.
It is suggested that a compare match timer is used to generate the tick interrupt, and an example
implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is
included in both main-full.c and main-blinky.c within this demo application.
The demo application defines configTICK_VECTOR within FreeRTOSConfig.h to be _CMT0_CMI0 (the compare
match 0 interrupt vector number). It is suggested that the provided
example implementations are used in most cases.
selected.
Source/Portable/MemMang/heap_2.c is included in the RX62N demo application project to provide the memory
full information.
